bennyuk2
Is there a way to animate the mobile menu when it is closed?
I can animate it to slide down on open, but I’d like to animate it to slideup when closed.
Is this possible? -
it is … but can be tricky.
Can you share a link to the site and I can take a look at whats possible -
bennyuk2
Thank you, much appreciated, link added in private info
Try adding this:
@media (max-width: 991px) { .main-navigation:not(.slideout-navigation):not(.toggled) .main-nav > ul { display: block; height: 0; overflow: hidden; } } .main-navigation:not(.slideout-navigation) .main-nav > ul { transition: all 0.3s ease; padding: 0 32px; } }
bennyuk2
Thanks Ying, the code did not work but it did give us enough info to adjust and find a solution, so many thanks.
Ben -
