pablo.lao
Hello!
Happy and having fun relearning the 2.0 version. Looks powerful!
But I’m trying to do the old trick I did with the effects where you can apply -say a filter- to another element calling its ID or class…and set it to ‘hover’ too if needed.Hope it makes sense and is not resolved elsewhere (tried hard to find it).
Very pleased to hear that 🙂
Hum…not sure I understand; can I see what you’ve done? and can you describe what you want to achieve?
Let me know!
pablo.lao
Hello, thanks for your response.
I knew it wasn’t easy to explain…
Let me try again.
There is an option when you apply an effect to an element where you can choose a ‘state’ and then also a custom selector as a target (it can be either self, inner container, background image, and said custom selector).
Having a second element with that class you can make the effect happen on it instead of on the element where the effect is activated.
Hope it clarifies it.
I see. It’s easy to do in V2 as well.
You can select the block, go to the style panel, and click the More button on the top of the right sidebar, click +NEW, you can then add your custom selector, in your case, it’s
:hover .hitme, with the Compoind selector option toggled.Here’s a screenshot for your reference:
https://app.screencast.com/8tUnEZsUHSlAn
https://app.screencast.com/ZhDwyWls62GIVThen you can change its style for the selector
.gb-text-xxxxxxx:hover .hitme.Hope it’s clear. 🙂
pablo.lao
Oh thanks! had not think of that approach.
