Brent Wilson
I have a custom post type with a taxonomy of years (for example, 2021, 2022, 2023).
I have a template element that I want to apply to any single posts of this post type with the taxonomy of 2022.
I have a different template element that I want to apply to any single posts of this post type with the taxonomy of 2023.
So far, this is pretty straightforward to do.
The problem is when I have a post with both the 2022 and 2023 taxonomies. In this case, I want the 2023 template element to apply, not the 2022 template element.
How do I set up the display conditions to make this happen? It seems like there is some conflict in this situation.
Hi Brent,
First of all, usually, creating taxonomies that are named by dates is a bad idea. The slugs for years for instance are reserved by WordPress for an archive page that retrieves all posts of a specific year. Make sure the the slug of your taxonomies, though named after years, won’t be actual years. Try
2021-a,2022-aetc. for instance.To clarify, do some of your posts have both 2022 and 2023 taxonomies? If so, for these instances, you can opt to override the display rule settings through a filter –
generate_element_display. Reference: https://docs.generatepress.com/article/generate_element_display/You’ll need to create a logic to check if a CPT has both 2022 and 2023, and then display the Element or not.
Brent Wilson
I will take care of the taxonomy slugs.
Yes, some posts have both 2022 and 2023 taxonomies (some also have a 2021 taxonomy). In those cases, I want them to use the 2023 content template element (ID 31580).
But if there is no 2023 taxonomy, but a 2022 taxonomy is present, I want them to use the 2022 content template element (ID 30090).
And if there is no 2022 taxonomy, but a 2021 taxonomy is present, I want them to use the 2021 content template element.
I am not a PHP expert. Can you give me a bit of guidance regarding how to format the necessary filter(s) for this functionality?
Also, when in the edit mode for a content template element, there is a dropdown in the right side settings for “Apply To”. How is this different from the display rules down below?
Try something like this:
add_filter( 'generate_element_display', function( $display, $element_id ) { if ( 100 === $element_id && is_single() && has_category(array(30090, 31580)) ) { $display = false; } else if ( 101 === $element_id && is_single() && has_category(array(30090, 31580)) ) { $display = true; } return $display; }, 10, 2 );Replace 100 with the ID of the 2023 taxonomy Element ID and 101 with the 2022 Element ID.
Getting the Element ID: https://share.getcloudapp.com/YEuDdrnQ
Repeat the steps for other instances like 2022 and 2021. Just replace the Taxonomy IDs in the code.
