Hello everybody,
I am using GeneratePress theme “Prime” as an Arabic store, I have understood from previous questions that I need to change the “Site Language” in WordPress settings to Arabic as well as taking care of typography. Is there any thing else I need to take into consideration when running an Arabic GeneratePress? Thank you.
George
For an Arabic (RTL) GeneratePress site, beyond setting the Site Language and typography, here are the main things to check:
RTL handling
- GeneratePress and GP Premium ship with RTL stylesheets that load automatically once Site Language is set to Arabic — so layout direction, menus, and the like flip without extra work. The key is that the language switch is what triggers them, not just a CSS
directionrule. - If you’ve added any custom CSS, that won’t flip automatically. You’ll need to mirror margins/paddings/floats yourself (e.g.
margin-left→margin-right), ideally via separate rules so it doesn’t affect LTR if you ever run multilingual.
Typography / fonts
- System fonts and many Google Fonts don’t include Arabic glyphs, so even with the right
font-familyyou can get fallback rendering. Use a font with proper Arabic support (Cairo, Tajawal, IBM Plex Sans Arabic, Noto Sans Arabic, etc.). If you’re self-hosting via the Font Library, confirm the font file actually contains the Arabic subset. - Arabic generally reads better at a slightly larger font size and increased line-height than Latin text, so it’s worth reviewing your base typography rather than reusing LTR values directly.
Store-specific (WooCommerce)
- WooCommerce has its own RTL stylesheet that also keys off Site Language, so product layouts, cart, and checkout flip too. Worth testing checkout, the mini-cart, and any variation swatches specifically, since those are the spots where custom styling or third-party plugins most often break RTL.
- Currency symbol position and number formatting are set in WooCommerce → Settings, separate from the theme.
Worth verifying on your install
- Any Block Elements / Hook Elements with custom layout (flex/grid) — check these flip correctly, as custom block markup won’t always inherit RTL behavior.
- Icons with directional meaning (arrows, “next/prev”) may need manual mirroring.
- If you later add a translation plugin (Polylang, WPML, TranslatePress), that’s a different setup — language switching there is handled by the plugin, not the WordPress Site Language setting alone.
One thing to flag: deep multilingual plugin internals and fully custom RTL JavaScript animations fall outside what we cover in support.
