aaronmckeon
Is it possible to easily filter an archive by various terms and/or post meta? If so, is it better to do it using an archive template or creating a page?
I have a custom post type
food-and-drink
that contains eating establishments and I need to be able to filter by cuisine (taxonomy), whether or not it allows pets (custom field), etc.Any advice on the best mechanism to do this would be appreciated.
I believe this plugin would be what you are looking for: https://wordpress.org/plugins/filter-everything/
Let me know if this helps 🙂
aaronmckeon
Okay, I installed that plugin and will give it a try. Looks promising. However, I still need to decide between two options for displaying posts:
— Option 1 – Create an archive that has the filters in it.
— Option 2 – Create a page that has the filters in it.It seems cleanest to do this as an archive, since it is an archive of all the posts in the
food-and-drink
post type. However, how do you setup the archive template in GenerateBlocks? The template (as I understand it) is only for the individual posts that display inside the archive. I would need to be able to update the template of the archive page itself so I can add the filter widget and style the page to my liking. Is this possible? Thanks.— Aaron
I don’t understand your requirement exactly but it’s probably best to do with by trial and errors.
I believe some users elect to go with a static page + GB’s Query Loop block + filter plugin for something like this.
aaronmckeon
Forgetting about the filters, I’m looking to customize the look and feel of the archive page beyond just customizing the individual posts in the loop. For example, I might want to put an image at the top, then a grid with two columns where I drop a short-code in the left column and the archive output of posts in the right column. I would need two elements (one for the individual posts in the loop, which I know how to do; and one for the main page). Is this possible or do I have to create a specific page instead of using native WordPress archives?
Based on your description above, I believe a Block Element Loop Template would be what you are looking for:
https://docs.generatepress.com/article/block-element-loop-template/ -
aaronmckeon
Thanks – That did the trick.
