cocostar
Hello Support Team,
I hope you’re doing well.
I’ve noticed that my article at the following URL is not centered on the page as expected:
https://fetichiste.net/comment-le-fetichisme-des-odeurs-corporelles-influence-t-il-lintimite/Could you please check why the content isn’t centered and advise how this can be fixed? It appears aligned to the left rather than centered in the layout, and I haven’t made any custom CSS that should affect this.
Thank you in advance for your help!
cocostar
Additionally, I would like to increase the width of the text/content area for all articles, without using widgets or page builders.
Is there a global setting or CSS adjustment that allows expanding the content width site-wide (for posts only), while keeping the same layout structure? -
The post layout is built by a block element – content template, you can find it at appearance > Elements.
The right side has a container and with a query loop block displaying a list of posts, but in your case, no posts are showing.
https://app.screencast.com/oWU39sU1faO47So do you want to remove the right side section on all your posts?
