JeremyL
I’ve noticed that my iPhone is auto linking the phone number in the top bar so it’s a clickable phone number to auto dial. The problem is, it is picking up my default link color which matches the top bar background color.
I have tried to edit the colro of the text to overide, but no matter what I do it’s coming in orange on orange, so you can’t see it.
https://www.crispstriping.com/
Recommendations?
JeremyL
Got it to work. Some weird work arounds though. Had to set the color at the container level because setting it at the text block level didn’t work.
Glad to hear you got it resolved!
It’s not really a workaround—this behavior is expected due to CSS specificity. The text block was inheriting the container’s link color instead of the default content link color.
JeremyL
The container didn’t have a color before.
It seems to be because the “a” tag color is set in the WP customizer, overides the class given to the div container around the a tag as the div is where the system sets all the colors at the block level with the GB class.
Not sure how the section container overides the a tag color and the div tag class doesn’t but somehow it does.
You didn’t set a link color for the text block.
Try setting the color to the text block > link selector, it will override the link color set for
bodyin customizer. -
JeremyL
I had tried that and it wasnt working. I just deleted everything and started over and that solution worked. So I guess I had some random setting somewhere on one of these selectors that was causing the issue. Oh well. Thanks for the help 🙂
