maxjames12
Hello, i am using generate press theme and in that site library, i am using explore child theme. but when i am trying to change the background image for the home screen it is not going backward. this is a pre-install image – https://snipboard.io/gkQrd9.jpg when i updated mine it is like this – https://snipboard.io/12n0eF.jpg i highlighted it with the red color.
Can you try set the 2nd root container’s
z-indexto 2?The container I’m referring to is the parent container of the 4 category boxes.
Let me know if this helps!
maxjames12
Can you clarify in more simple words? As the word container is not familiar to me. Please include step by step details or screenshots or videos.
Hi Max,
Yes, we can share a screenshot. Can you share admin login credentials through the Private Information field? I’ll take a screenshot of the setting you need to change.
maxjames12
Sure, please provide me screenshots.
I just tried changing the background image of the hero container block, it doesn’t seem to have the issue you described.
Can you change the background image first and if the issue occurs, we can take another look?
maxjames12
PLease Provide me step by step how to change the bachground of it
Here’s a screenshot that should assist you: https://share.getcloudapp.com/7KuW0Xne
Kindly follow the arrows.
maxjames12
Thank you so much, issue resolved!
You’re welcome, Maxjames!
