Background Image Overlay
  • Hello. How do you create a background image, with a gray overlay and white text on top using GB 2.0? When I do it, and apply the overlay it applies it to the text as well, and not just image. And when I adjust opacity it does it for both the image and the text. Thanks!
    you can add both background image and gradient/overlay via the backgrounds panel, make sure you add the image first, then the gradient/overlay, so the overlay can sit on top of the image.
    You should not have the text issue with this setup.
    https://app.screencast.com/Rg8NpP93f9DXb
  • Ok thanks, I’ll give it a shot.
  • No Problem 🙂
