Background Image with Overlay/Opacity
    I have a container with a background image, softened to 0.5 and a gradient set. But now it looks like the content (headline and text) has also been softened. Do I have to set up this container differently or is one setting still wrong?
    Screenshot: https://postimg.cc/56vCkCpD
    Many thanks
    Markus
    Try to set the text containers’ position to relative so they can sit on top of the background image.
  • Ah, ok… works. Thanks Ying
  • solved
  • You are welcome   🙂
    I have another problem here where I only wanted to soften a background graphic. The text containers are set to relative, but everything, including the text, images, and headlines above them, is also softened.
    Why?
    What’s now the problem?
    Please see the page below…
    Could you re-add the page link? It doesn’t appear to be included.
  • Please see below…
    In this case, I would suggest removing the background image and instead inserting it as a normal image just after the Boards container with absolute positioning (Position settings, set Position to Absolute). You can then size it with the image size controls, position it with the INSET controls (Position settings from the right) and set the opacity on the image itself, not the whole Board container.
  • Ok understand… just do it like your suggestion, works.
  • Great, no problem!
