JB_Walton
Probably a very simple question and even simpeler answer?
I search everywhere but couldn’t find an answer.I have a container with background image.
On mobile I want to change that image and position.
So far so good.But is there a way to stop loading both images?
Both are loaded and css is executed according to the device.Alternative:
I would use the same image but different position.
How can I do that?Regards,
Jan -
George
If you select a different background image on mobile and change the position value, the desktop image is not going to load. You might see it in the Inspector as on being loaded but will have a strike-through effect on it.
Also, if you switch to mobile on the browser inspector and switch to the Network tab, you will see that indeed the desktop image is not being loaded at all in the list of files.
JB_Walton
Thanks for clarifying this.
Looks like my caching plugin messed things up with critical css loading.
That’s why it looked like loading both images.I went back to one image and extra css for mobile, where the position of the image is changed.
George
Ok, no problem!
