Background inlcuding block element “side header”
  • tobiasruderer
    Hello there,
    I created my header with a block element (Element Type: Site Header) which works fine. Now i want to create individual backgrounds for different pages. Is there any way of doing this in way which includes every page as a whole, for example setting a gradient background spanning over the header and the body of the page? I know I can create a Hook Element for changing the background of the Site Header and use the outermost container element of a page to change the background of the body, but this excludes the possibility of using gradients or images. I hope I’m making it clear. Thanks for reading!
    Tobias
    not sure why you think it excludes the possibility of using gradients or images, you can add gradients and images to a container.
    let me know if I miss anything.
  • Hi, thanks for answering!
    Yes, I think you missed something. the question is: How can I create a single background (image or gradient) that spans the body section of my site AS WELL AS the header (which is a block element) – ideally differently on different pages? If I target the body section and the site header seperately, all I can do is monochrome backgrounds if I want it to appear continuous.
  • How can I create a single background (image or gradient) that spans the body section of my site AS WELL AS the header (which is a block element)
    You can set site header background color to transparent, so you can see the body background underneath the site header.
    If you only want to add 1 background to the entire site, you can use the Backgrounds module in customizer, but you want to add different backgrounds on a page basis, it’s better to use CSS.
