I tried to turn on sticky navigation.
It includes sticky navigation logo and menu.
However, the background shows transparent.
Is it possible to set a color background for the sticky bar?thanks
the sticky navigation gets its colors from the Customizer > Colors > Navigation
Are those colors set ? -
At Customizer > Colors > Navigation, we can set initial, hover and current color for primary navigation.
However, I have transparent logo(left) and primary navigation(right) laid on top of a background image.
Therefore, is it possible to trigger the navigation color on while sticky navigation shows? -
Can i see your site ?
The logo is while with transparent background.
I was thinking that could we assign the sticky navigation bar a background color? -
OK. Do this:
1. In Appearance > Elements, edit the element titled:
Merge
1.1 go to its Site Header Tab and check the Navigation Colors option.https://docs.generatepress.com/article/header-element-overview/#site-header
In here set the Colors that you currently have for your navigation. ie. a transparent background and white text.
These will apply to the merged site header only.
2. Now go to Customizer > Colors and set your Navigation background and link colors.
These colors will apply to the Sticky Nav and anywhere the header is NOT merged. -
Not sure if I understood it fully, anyway, it seems now.
thanks very much.However, the logo becomes larger on sticky navigation bar.
It is normal? could we set the logo size for that? -
The sticky nav logo gets its height from the menu item height.
To change the logo without affecting the menu items, try this CSS:.main-navigation.sticky-navigation-transition .navigation-branding img { height: 48px; }
Got it. Thanks. This works well.
Do we also need to set it for tablet and mobile phone mode? -
If you want to you can do:
#mobile-header.sticky-navigation-transition .site-logo img { height: 50px; }
thanks. David.
How was the size of logo determined by the theme?
I set 200px in width at Site Identity > Logo Width.when I switch to mobile or tablet mode, the logo becomes smaller automatically…
The theme resizes the mobile header logos width to 100% and it Height to the Mobile Menu Item Height ( set in Customizer > Layout > Primary Navigation. This is to ensure it fits in the mobile header.
