Please let me know how to edit the author bio.
Currently it shows
Lorem ipsum amet elit morbi dolor tortor. Vivamus eget mollis nostra ullam corper. Pharetra torquent auctor metus felis nibh velit. Natoque tellus semper taciti nostra. Semper pharetra montes habitant congue integer magnis. -
Can I see the author box on your site to inspect how it’s built?
Hi Ying.
Thanks for your prompt reply.
Please look at the bottom of this post.
https://utka.com.au/how-to-prepare-and-train-for-sydney-marathon/Regards,
Fred
Can you go to appearance > elements, check if there’s a content template assigned to posts > all posts?
If so, edit it, select the text block with class gb-text-bbcd130a, and set its dynamic tag to
{{author_meta key:description}}. -
There is no such “Content Template” in elements.
There are:
Template – 404 page
Template – No Search Results
Template – Single Post -
Edit the Template – Single Post element, then replace the existing author bio text with the following dynamic tag: {{author_meta key:description}}
You can refer to this video for guidance:
https://cln.sh/LVMn8s1ts2S4mcfl8lqj -
Thank you!
The issue is now resolved by your detailed yet simple instructions with the quick video.Thansk a lot,
You’re welcome!
