Blank Page
  • Dear Team,
    How to have a blank page so that I can use otter or any page builders?
    Using generatepress blog theme. But for Homepage (Business page), i would like to use some custom page using block builders.
    Thank you
    Sarathy
    1. enable the Disable Elements module in Appearance > GeneratePress:
    https://docs.generatepress.com/article/disable-elements-overview/
    2. Edit your page,
    2.1 use the disable elements metabox to remove the theme elements you do not require,
    2.2 set the Content Container to Full Width
    https://docs.generatepress.com/article/content-container/
    This will allow to create a full width empty page with no theme spacing ( padding or margins )
    You can then construct the page in the block editor using GenerateBlocks or any other blocks you choose to use.
