Hello.
I am having problems with the ELEMENTS section. When accessing any element other than “blocks” the screen comes up blank, only the title comes up.
I have deactivated all plugins, deleted all CSS, cleared cache…etc. and it’s still the same.
Thanks in advance
It’s due to bad data stored in certain admin user account, can you try creating a new admin account and login with it to test?
Hello Ying.
I have created a new user and it is working correctly.
Thank you very much and good day. -
I just experienced this issue and creating a new account solved it. Hoping the cause is found!
whebbworks
Running into the same issue for the second time. First time we used a block element as a workaround for the missing hook element, this time I found this solution. Any idea why it is happening? It is not visible for one admin, but okay for another. What is the bad data that is being stored?
That’s a mystery…
