Block Backend looks different
  • Hej, I have installed GeneratePress with GeneratePress One on different websites but the backend for blocks looks very different. Any help?
    one
    two
    Your screenshots show that you are using GB’s v2 blocks.
    If you are not seeing the same on other sites, it may be because they are still using v1 blocks, which can be turned off at generateblocks > settings.
    However, this is a one-way ticket, if you turn it off, all new blocks will be v2, you will not be able to go back to use v1 again.
