Block Element not appearing
    I’m trying to create elements but I’m not able to do so because the “block element” is missing in the sidebar. I don’t have the block where I can select the element type (hook, site header etc)
    Everything is updated, I’ve disable all plugins and this block is still missing. Any idea where the issue could be coming from ?
    I don’t believe I’ve heard this issue before.
    Can you confirm that this is the step you’ve gone through?
    https://docs.generatepress.com/article/block-element-overview/#creating-a-block-element
    If yes then can you provide the dashboard login with all plugins disabled except for GP Premium?
