rafaelmagic
Tech,
Hope all is well.
I created a custom Footer Block for my website with Generate Blocks.
The footer just has two issues:
1) The Footer needs to be centered.
2) In tablet size, some of the footer text flows oddly in my “Service” area. I am trying to get it to stay in one line.Thank you,
To fix the first issue:
Select the inner container that wraps the Grid block and set the left and right margins to auto.I did not see the issue on the second one. Do you have a screenshot of what you are referring to?
rafaelmagic
Alvin,
Footer, centering is fixed. That also fixed the issue with the text.
Is it Better to do?
1. Outter Container, Inner, Grid
or
2. Container, Grid -
In this case, option 1 is better and much easier to implement.
