Block – Loop Template with infinite scroll
    I’m using the Block – Loop Template from GBP to customize the layout of my posts across categories.
    Insite the template, I have the standard Query > Looper > Loop Item structure with an additional container containing the pagination.
    Furthermore, I did add a new page following the same structure to display all my posts.
    The GPP modules section (Appearance) lists the “Blog” with:
    Set blog options like infinite scroll, masonry layouts and more.
    However I was not able to figure out how to use the infinite scroll?
    Is the described approach of using a query loop different from using the _Blog_?
    I’m using the GPP 2.5 with GBP 2 beta 5.
    Currently, the Infinite Scroll option cannot be applied to the Query Loop, unfortunately. We’ll explore a different option specifically for the GB Query block in the future.
