Block setting size question
  • I’m putting together a post where I want to use 10 images. Each image is a feature image from other posts. The original feature images are large (1200px X 800px). The new post will display them at a fraction of the size. If I choose the Block Settings Size to “Medium”, will that reduce the actual size of the images, and therefore reduce the load time?
    Thanks.
    Yes, it will 🙂
  • Thanks so much!
  • No Problem 🙂
