pringletech
I have a non-GeneratePress theme site that I am trying to use GBP2.0 for new pages.
I copied some blocks from a starter site and they render correctly. But when I make a local style change I get no UI and the following message,
An error has occurred, please reload and try again
I tried adding new blocks, and the same thing happened.
Thank you as always.
I tested by creating a new page and adding some GB blocks, but I don’t see the error you mentioned. Does this issue only occur on specific pages?
pringletech
try the url I added to the private section, last line.
Okay, I see the error now. Can you try deactivating other plugins except for GenerateBlocks and GenerateBlocks Pro to check for a possible plugin conflict?
pringletech
I will need to test this on a staging version of the site. I will work on this today and give you an update.
Sure, just let us know how it goes!
