Blog Columns based on screen size
    In my website I want to increase number of columns for the devices which are larger than 1440px.
    Settings:
    https://i.postimg.cc/HLg0k5bP/Screenshot-2024-08-01-at-6-05-34-PM.png
    https://startupwebsite.net/wari/?hkdev_temp_access_key=BlQLw867siRzybfXWlWE this gives access to site and you have visit the blog page from there.
    Current settings are getting applied to all devices but I want more granular control.
    We can overwrite using css but if some settings are changed from customize like instead of 3 if made 2 then dynamically applied class will get changed and our changes will not work.
    What is the best workaround for this?
    Regards
    if you want granular control then using some CSS would be best:
    /* default 2 columns in mobile */
    #main .generate-columns-container {
        --blog-column: 2;
        display: grid;
        grid-template-columns: repeat(var(--blog-column), 1fr);
        column-gap: 10px;
    #main .generate-columns-container > * {
        width: 100%;
    #main .generate-columns-container > *:is(.gb-container, nav) {
        grid-column: 1/-1;
    /* set tablet columns */
    @media(min-width: 769px) {
            --blog-column: 3;
    /* set desktop columns */
    @media(min-width: 1024px) {
            --blog-column: 4;
    In the CSS there are 3 instances of: --blog-column: 2; each one setting the number of columns for the size of device that is commented.
  • Hi David,
    Thank you for your quick response.
    Best
  • You’re welcome
