blog layout element
  • Hi, I can’t get my blog layout element working properly. I would like to have my blog title in different columns. But as seen in the link, I only have them one on top of the other. I tried a grid but it only duplicates them on the same row. Help please?
    Only keep one post layout in the content template, you do NOT need to use Grid block in the content template.
    And if you want to activate the columns, go to customizer > layout > blog, and check the Display posts in columns box.
  • Thanks. I did it. And I can see two columns. But there is too much space in between and there are two narrow. How can I make it look better please? I don’t see any options in customize.
  • I found how to make the columns wider. But it’s still not looking very good. Also it’s not centered on the page. How can I do that please?
    Edit the Content Template element, and set the Width of the main container to 100%. It’s currently set to 50%, which is why it appears narrow.
  • I made some changes. It looks better. I just don’t know how to align on the left the picture with the text.
  • Could you clarify which part you’re referring to? I’m not entirely sure what you mean.
