Well, a plugin example would be something like this: https://wordpress.org/plugins/search-filter/
Though, I don’t think that enables AJAX loading.
TAZ32
Thanks – I’ll check that out.
Can you share the link to the page you showed in your screenshot?
TAZ32
Yeah, sure!
Let’s tackle the spacing first.
Can you share the link to the page you showed in your first screenshot? The one with the red lines.
TAZ32
Done!
Hi Taz,
Sorry, your response somehow slipped through our system.
For clarity, can you reshare the screenshots and re-explain the remaining issue?
Please don’t remove the data you’re sharing in the Private Information field for now so we can re-read it if needed.
Re-uploaded. Sorry for deleting that, I thought there might be a char limit! 🙂
#1 Spacing of featured post.
Edit the Element for the featured post.
Select it top most Container Block.
In Sizing change theWidth
to100%
In Spacing > Padding Left & Right add 30px.NOTE on Sizing, don’t used fixed unit widths such as 1200px as they will break the containment and cause overflow if you need to define a width, then set the Max Width instead.
#2 The search results are using the same Page Hero element as the rest of your site.
You need to exclude the Search results from that hero.#3 Third party plugin is required like FacetWP of Advanced Search and Filter.
TAZ32
Perfect! 🙂
You’re welcome
