Blog Loop Template – Remove Underline from Links
  • I’ve added the following CSS to my site:
    .no-underline a {
    text-decoration: none;
    In my blog loop template, I input .no-underline into additional CSS Class(es).
    My title is still underlined. Could you assist in getting the underline removed? I’d also like to remove underline from comments.
    Make sure you remove the ., only no-underline needs to be added to the field.
    And your CSS isn’t working as well; remove the CSS before the actual CSS:
    https://app.screencast.com/C2Q3QUHN5F88A
  • Perfect! Thanks so much!
  • You are welcome   🙂
