john hogan
I would like to create a “primary” post at the top and then a list of other blog post with a pagination.
Use the 1st link to see what I currently have.For the post page, i would like the title, breadcrumbs, and space between the post and the right sidebar.
Is there more I should add for SEO purposes? -
Hi John,
How do you define primary post? Will it be from a specific category or tag?
john hogan
Specific category.
Ok.
You can edit your current block element – loop template for blog, and add a new query block on top of the existing one.
For the new query block, click add parameter button, select taxonomy > category > the category name + include, and set a posts per page value, eg. if you want it to only show 1 post, then set it to 1.
For the existing query block, if it’s using the Inherit query from template option, toggle it off. Then click the ” add parameter button, select taxonomy > category > the category name + exclude, so it does not show any posts from the category.
Let me know if you have any questions.
