Blog page missing H1
  • Hi great team!
    No hurries for this question, but my blog page does not have an H1 tag I see with a heading tag checker site.
    Apparently several other sites I’ve created also not.
    So I think I’m doing something wrong 😉
    What could be the issue?
    I thought about that I maybe disabled title within GP layout widget but that widget is not visible when I edit blog page.
  • fernandoazarcon2
    Hello there,
    You may have disabled the page title for the Blog.
    What some web designers do is add a Block Element – Page Hero that has an H1.
    Reference: https://docs.generatepress.com/article/block-element-page-hero/
  • Hi Fenrnando, thanks for reply. I thought also maybe I’ve disabled the page title but could not find the GP layout widget within the blog page. I’ve removed blog page from Dashboard, Settings, Reading. Than I could check and the title was not disabled. Also I could see the H1 tag in the source code.
    But now I’ve enabled the blog page as the blog page through Dashboard, Settings, Reading and I could not find the H1 tag.
    Do you have an idea what I can do now? I’ve also added H1 as a tag as Element (to the blog page) but nothing happened.
    I’ve added an admin account for you. Thanks in advance!
    if you use a Element to add the H1, can you make sure the Display Rules are set to the Blog ( which is listed at the top ) and not the static page you created.
  • Thank you David for the suggestion. I’ve tried that but than I then see the word “Blog” above all blog messages.
    But found that now, I’ve also had the hook set to before_content but had to of course select before_main_content 🙂
    Problem solved!
  • Glad to hear you got it resolved!
