Blog page pagination
  • Hello! I created a blog site with Generateblocks. Unfortunately, the option to turn pages does not appear under the posts. The settings, how many posts should be on one page, are fine. Setting it in Settings / Reading caused the blog page to fall apart, it doesn’t work. I cannot add a pagination parameter to the query loop on the right side of the blog editor, because it is inactive. What is the solution?
    Not sure I understand the issue, how doesn’t it work? Can I see a screenshot of the issue?
    To add Paginatino to the query loop, you need to click the + icon:
    https://docs.generateblocks.com/article/query-loop-overview/#pagination
  • Hi Ying! Thank you very much! I found the + icon and the problem was solved. It was really simple. Often the solutions are simple, we just don’t figure it out. Thanks!
  • You are welcome   🙂
