connect4consulting
How about the blog post display on the home page? I’m trying to get it to just be a grid – 4 columns across and 3 rows and then pagination.
Select the looper block, set its
displaytogrid, and setgrid-template-columnsto1fr 1fr 1fr 1fr -
connect4consulting
Ying,
That didn’t quite do the trick. I’ve cleared the cache. What’s going on?
Thanks,
Gabe -
You have a custom selector that set the first post to span 2 columns and 3 rows.
.gb-looper-25cad51b :first-child { grid-column: span 2; grid-row: span 3; height: 80%; }Can you select the looper block, click the manage selectors button, check if there is such a selector, if so, delete it.
connect4consulting
As always, you rock! Thanks a ton!
