I am unable to reduce the gap between my featured image in the blog post and the table of contents in mobile view.
Can you please help me fix it?
Hi Odin,
The parent container of the image has a
heightset to 500px on mobile, can you remove it?And it also has a negative
margin-bottomset, try setting it to 0 on mobile. -
I removed the negative margin and set the height to auto, but the gap has increased. How can I reduce it?
I checked the height and bottom margin on the container, and both are still set to 500px and -200px. Did you happen to revert the changes?
What Ying suggested should fix the large gap issue, can you double-check if those values were updated correctly?
I have changed it already. Maybe it’s because of the cache. I will clear it.
After clearing the cache, it got fixed. Thank you.
Glad to hear that! 🙂
