Blog settings not being applied for a custom post type archive
  • I have two CPTs, testimonials and portfolio-new. I have applied some different blog settings for their archives.
    // Portfolio and Testimonial archives
    add_filter( 'generate_blog_get_column_count','gm_custom_column_count' );
    function gm_custom_column_count( $count ) {
        if ( is_post_type_archive( 'testimonial' ) || is_post_type_archive( 'portfolio-new' ) ) {
            return 33;
        return $count;
    add_filter( 'generate_blog_masonry','gm_testimonial_masonry' );
    function gm_testimonial_masonry( $masonry ) {
        if ( is_post_type_archive( 'testimonial' ) ) {
            return 'true';
        return $masonry;
    add_filter( 'option_generate_blog_settings', 'gm_custom_featured_column_page_settings' );
    function gm_custom_featured_column_page_settings( $options ) {
            $options['featured_column'] = false;
        return $options;
    The both have a content template assigned, a separate one for each. I only see the testimonial archive in columns, though, the portfolio-new displays one post below the other, no columns. I have cleared permalinks, no cache on the site, it’s a local install.
    What could be the issue?
  • Update: if I include conditional for the portfolio-new CPT for the masonry filter, it seems to work, columns are displayed but I obviously don’t want masonry layout for the portfolio-new CPT.
    add_filter( 'generate_blog_masonry','gm_custom_masonry' );
    function gm_custom_masonry( $masonry ) {
            return 'true';
        return $masonry;
    For columns to work, you need to enable the columns first before setting columns number:
    https://docs.generatepress.com/article/option_generate_blog_settings/#options-%E2%80%98column_layout%E2%80%99
  • It’s already set in the blog settings, I don’t think I need to set it again. Anyway, I tried the following, no change.
            return 33;
        return $count;
    add_filter( 'option_generate_blog_settings', 'gm_custom_column_page_settings' );
    function gm_custom_column_page_settings( $options ) {
            $options['column_layout'] = true;
        return $options;
            return 'true';
        return $masonry;
    As I said, columns are displayed for the testimonial CPT.
  • I need to see your site’s backend.
  • See attached. Blog filters are towards the bottom. Archives can be accessed from the top.
  • Your solution here seems to be working. Not sure why it works for the testimonials, though, since I haven’t applied the generate_blog_columns filter for the testimonial CPT.
  • So it means the page doesn’t meet the condition of is_post_type_archive('portfolio-new').
    I guess you have to use this condition in this case: 'portfolio-new' === get_post_type() && ! is_singular()
  • Both CPTs should not have been set to display columns since columns have been set from the Customizer and columns should display by default on their archives. I have not set the columns to appear for the testimonial CPT in any other place but I get columns for it. For the portfolio-new CPT, I had to use the generate_blog_columns filter in order to get columns. I shouldn’t need to do that, that’s what I mean.
    GP does not know about the CPTs, you need to use the filter to tell it.
    So if you remove all those filters, the testimonial archive still gets columns?
  • No, it doesn’t but it does when the generate_blog_masonry filter for that CPT is used! Very strange…
  • Ok, I think when masonry filter is used to enable masonry, columns seems to get applied automatically which makes sense, I guess.
    Thanks for looking into it!
