Can anybody have a look? I want to have the boxes at the bottom-Line of the Box outside
Your site is under construction mode. I can not see it.
However, check this article: https://docs.generateblocks.com/article/equal-height-grid-containers/
Let me know if this helps!
Hello Ying,
thank you – but i did not find a solution.
i have deactivated the Plugin, can you have a look? 🙂
That would be very nice.Thanks a lot,
Jenny -
looking at the Grid, for reference the list view will look something like this:
Grid Block ---- Container Block #1 ( Column has background image ) ---- ---- Container Block #2 ---- ---- ---- Container Block #3
Select Container Block #2.
Set its Layout > Display to Flex , and the flex Direction to Column.
Set its Sizing > Height to 100%Select Container Block #3
Set its Layout > Flex Child > Grow to1
Repeat this for the blocks in each of the Grid columns
Thank you David 🙂 it worked.
Glad to hear that
