Brand Theme: Menu Color, Uppercase Text
  • I’m currently using the Brand theme and would like to know how to:
    – Change the colors of the menu items (OUR BRAND, IDENTITY, COLORS, etc)
    – How to remove uppercase for the same menu items
    Thanks in advance.
  • Hi Alex,
    To remove the Uppercase setting, in Appearance > Customize > Additional CSS, edit this:
    .main-nav .title a,
    .slideout-navigation.main-navigation .main-nav ul li.title a {
      text-transform: uppercase;
      font-weight: 700;
      letter-spacing: 0.1em;
      margin-top: 40px;
    to this:
    .main-nav .title a,
      font-weight: 700;
      margin-top: 40px;
    For the color, do you want different colors for each or the same?
  • Hi Fernando,
    I’d like one color, but give me both options (one color and different colors).
    Thank you.
  • Try this for the same color:
        color: red;
    If you want them to have different colors
    1. Go to appearance > menus, add a new class to the menu item. Eg. add brand class to the Our brand menu item, add identity class to the identity menu item, etc.
    https://app.screencast.com/R6WmWEJTxoL4i
    2. Add CSS according to the class you add, eg. for the our brand menu item, the CSS would be:
    .main-navigation .main-nav ul li.title.brand a {
        color: blue;
    You can keep on adding CSS for other menu items, eg. for the identity menu item:
    .main-navigation .main-nav ul li.title.identity a {
        color: yellow;
  • Hey guys,
    I appreciate your help, but what I meant was the items on the main page (not the navigation menus area).
    The default color is purple, and there’s a line under it of the same color.
    I would like to remove uppercase and change the color to something else.
    Thank you.
  • I see. Thank you for clarifying.
    Here are a couple of screenshots to show you an example of the settings you need to change when selecting the specific Headline Blocks on the Front Page:
    https://share.getcloudapp.com/7KuXv4GL
    https://share.getcloudapp.com/kpuRQ92Z
