Cordovil
I m using your Broadcast theme and using the recent posts page as the homepage. However, I would like to delete the word “Blog” on top of it.
How can I proceed?
best regards
claudio -
The default Broadcast template is already using the latest posts as the home page and I don’t see a Blog title on it:
https://gpsites.co/broadcast/What modifications did you make after the import and can you link me to the page in question?
Cordovil
I m sending private information to you
That Blog word is also coming from an Element I believe
It’s not in the original template so I can’t tell you which one it is:
https://gpsites.co/broadcast/Can you try deactivating each element to test?
It’s likely the one that displays the page title – you need to add the front page to the exclusion of that element.
Cordovil
Ok Leo,
I will do it and let you know about what happened.
It is curious because I’m using the original version of the Broadcast theme. I didn’t make any changes on it.
Many thanks
CC
Cordovil
Hi Leo
You are right.
The issue was in the Global Hero. As I maintain Global Hero and excluded it only from the Blog page the problem was solved.
Many thanks again, especially for give me support on Sunday. 🙂
kind regards
cc
Cordovil
Hi, Leo
After some hours working in the site I made a mess with the Elements settings.
Would you please to give me the settings of Global Hero, Page Hero and Post Hero related to the Broadcast theme? I think that the problem is in the settings of Elements that I messed up.
You could check in the url that I’m giving you the mess in the main menu that is now hidden behind the images of the homepage.
thanks
cc -
Hi Cordovil,
Here are the Element Settings and Display rule settings for the Page Heros:
Home Hero: https://share.getcloudapp.com/L1uvjB8R – https://share.getcloudapp.com/12ukn4QG
Posts Hero: https://share.getcloudapp.com/DOuK0qPk – https://share.getcloudapp.com/Apug0zPQ
Global Hero: https://share.getcloudapp.com/v1uWpYnB – https://share.getcloudapp.com/8LuYOolm -
Cordovil
Many thanks, Fernando.
I will try it and let you know.
Cheers
Cordovil
Hi Fernando,
I follow your guidance, but the problem persists, as you could see in the URL that I sent you in private way.
Could you see a solution to this? All this mess start when I tried to combine knowledge base plugin with WPML plugin. I removed the knowledge base plugin and the problem persists.
claudio
Cordovil
Hi
It would be possible to reset the Broadcast theme without to lose everything that I made? Dozens of hours of hard work .
thanks
cc
can you confirm the URL ? The one in the Private Information is not working for me
Cordovil
Now it is ok you could check again .
tks
cc
I am afraid the link is still not working for me.
Do you want to try adding it to your reply ? and not in the private information.I can delete it once we have got it working.
Cordovil
criancara.online/blog
You could see that the first line of the images has a cut.
That is the only glitch that I find. If it is solved, everything is ok. I presume.
The problem is only in tablets and notebooks. It seems ok in mobile.
I still cannot access that URL, its reporting this:
DNS_PROBE_FINISHED_NXDOMAIN
Which means the URL cannot be found in the DNS tables.
As that site live ?
If it is, is it restricted to a certain country ?
