Cordovil
Nope. To me it is alive and abroad. Did you refresh your browser? Try it again please.
I can not access your site either, unfortunately.
Cordovil
Please try criancarara.com
So , let me know if it is possible to go back to square one , reset again the Broadcast theme and don t lose any content that is there.
thx
P.S . : It is curious because yesterday a friend of mine got access to the site in a seamless way.
Still can not access the site.
What kind of content are you referring to?
Cordovil
the content that is located at the url that you can’t access . I had a hardware to put it there. Texts and images basically.
Do you have someone that could act as a consultant to repair a glitch in this site? I would like to have a more pragmatic solutions before put all my job in the dump.
thanks
I would recommend reaching out to your host and making sure they back up your current site.
Then you can try to remove the imported template and re-import it again.
if the content you added is to a new page/post created by you, removing the imported template would not affect that.
Cordovil
Thanks Ying
How can I proceed to remove the imported template if needed?
Does it affect the English version there ? WPML Plugin
cheers
cc
Here’s the doc:https://docs.generatepress.com/article/using-the-site-library/#removing-an-imported-site
Removing the imported template will only remove the content and settings that you imported, if the content is already there before importing the template or you added the content via a new page/post, the content will not be removed.
I haven’t used WPML plugin myself, not sure on this.
Cordovil
One last question… below in the private section of this message.
I re imported the template and everything is ok.
Many thanks for your support.
The topic is already marked as resolved so all private message has been erased.
Do you mind opening a new topic for the question?
This topic is already two pages long with lots questions unrelated to the original topic.Please also make sure to keep the actual question/description in the forum topic and only use the private info field for site URL etc.
