Broken layout
    I noticed that the Content Template Layout on that category is broken. On the first row only 1 post appears where should be 2. I found some div class=”wpc-custom-selected-terms” which I don’t know where it comes from..
    Would you please help with that.
    Regards
    It seems from a filter plugin. Can you disable your filter plugin to test?
  • It was from the Filter plugin Filtereverything.pro. Fix it successfully with them.
    Regards
  • Glad to hear that 🙂
