blarney27
Hello. Where I use the GB 2 query pattern I get the following error showing up. Do you know why and how I can fix it?
I’m not sure what you mean. What is the exact error you see?
It looks like you are using dynamic tags in the URL field. Is that the case?
blarney27
I am using the query block pattern (one of them) from GB2. And at the bottom of the container it has an image, and author name and date of post (so yes dynamic tags).
I do NOT see any of those links you added in the private info field on this specific post.
I think it’s a false error.
blarney27
Ok great, thanks!
No Problem 🙂
