Bug? Button block when using highlight for colour loses text space
  • Morning
    I need a button that says “Learn More…” that has the 2 words in different colours – I used highlight to change the colour of the text. But when I did that the space between the two words disappeared.
    Code showing the difference
    <div class="gb-element-65427ecc">
    <a class="gb-text gb-text-b31c6cc3">Learn More...</a>
    </div>
    after
    <a class="gb-text gb-text-b31c6cc3"><mark style="background-color:rgba(0, 0, 0, 0)" class="has-inline-color has-base-3-color">Learn</mark> More...</a>
    </div>
    So the space between learn and more doesn’t display
    I am also using letter spacing = 2 – but even when I remove that we still have the same issue, and when I Highlight the 2nd word it still happens
    Site currently in progress and behind a wall – but just thought that I would mention it. and I will come up with a new way to change that colour using CSS only
    Thank you
    Sarah
  • Hi Sarah,
    That isn’t a bug – it appears to be the expected behavior when the Button block is set to Display: Flex or Inline Flex.
    Try changing the button’s Display setting to Inline instead.
  • Yes you are correct Display inline fixes that – but as the display: Inline Flex is the default … anyway thanks for the solution – still random but hopefully this ticket will help if others come across this quirk
  • Sure, no problem 🙂
