Bug issue – Images in one section are getting out of their container size
    There seems to be a bug with images getting out of their container size (images max-width is set to 100% by default to avoid that)
    https://clevenio.com/#tab-section
    You seem to have a fixed height of 460px for the container with the Tab-Image-Section class. Trying removing that along with the padding-top and padding-bottom values.
  • Thanks George.
    There wasn’t an issue when i first implemented that. It happened recently.
    Removing the height on the container didn’t fix the issue, as the image was getting it’s own size.
    It was fixed with setting the image height to 100%. Means it gets the container’s height (along the padding in this case)
  • Oh, great, no problem!
