Mohammed Anis
thanks for GP and GB.
It seems there’s a bug with the global styling with image block; it’s not taking the global style css classe, so globlal styling is not being applied.
I could eventually get around that by applying the margin to the headline instead. But this is needed for more control.
check the joint link where the global styling css class is applied to the headline but not to the image block.
Mohammed Anis
There’s also another bug.
Sometimes the global styling class break when you edit.
Yes, that’s a known bug with the image block.
As we are in the process of changing the structure of the image block, this bug will take longer to be fixed.
Sorry for the inconvenience.
Mohammed Anis
Thanks,
how about the other bug i mentioned?
Can you explain a bit more? Can not quite picture this.
Any chance you can record a video to show the issue?
Mohammed Anis
Sometimes When i make edits in the global styling.
The global css class that i set change to a random number. And then the global stlying is lost.
I have to rename the global css classe the same as it was so it re apply.
Hum…I checked GB’s Github issues and didn’t find such an issue being reported.
It’s difficult for us to define the cause if the issue is not easy to be replicated.
If it happens again, can you try disabling all other plugins to eliminate conflicts from other plugins?
If any chance you can record a video when this happens, it will be very helpful!
Keep us updated!
