Buggy cart-count function
  • Hello, I am using GP for an ecommerce build and something I’m having a hard time with is the small cart-count being buggy. Whenever I add an item to my cart, the cart count does NOT update. in fact it visually updates and then immediately rolls back to the previous cart-count.
    For example if i have 4 items in my cart, then add 2 more products, the cart will flash 6 items then immediately roll back to 4 items, and when i open the side cart it will also show 4 items only. However on the checkout all items are visible.
    I have also tested by removing ALL CUSTOM CSS, and ALL FUNCTIONS.PHP and the problem still persists, which makes me think its NOT anything from customizing the theme.
    Any help is much appreciated.
    Can you please, clear and deactivate the LiteSpeed cache? Does the issue still persists?
  • So that did help with Refreshing the page, the mini cart is now accurate
    Is there a way the mini cart can update AS ITEMS are added? Without having to refresh? So it just automatically refreshes any time a product is added?
  • for the record, ive swapped out for funnelkit, and its all fixed now
    closing this thread
  • Ok, good to know, good luck!
