Built with Generatepress
  • After updating Generatepress it automatically added to my site footer text: “Built with Generatepress”. How to get rid of it? I don’t see option in site customisation settings.
    Go to appearance > generatepress, enable the Copyright module.
    Then go to cusotmizer > layout > footer, remove the text from the Copyright field.
    Let me know if this helps!
  • Hi, thank you for your reply.
    First thing I tried was to check customizer – layout – footer. But text in the copyright field is empty (even I have custom text in my footer).
    Next I disabled copyright module in Generatepress but problem remains.
    My editor in WordPress is Elementor. I don’t know if it somehow overrides settings?
    If your footer is not using an Elementor template, the footer copyright settings should work.
    If you’d like, you can provide a temporary login so we can take a closer look.
