I’m trying to create unique 3 separate Content Template elements for pages/child-pages
COUNTRY
-STATE
–REGIONApart from individually adding each individual region/state/country manually in ‘Add Location rules’ for each of the 3 elements (which will be painful with 200+ pages), is there a better way to do it?
Thanks,
Pat -
It’s not possible from the UI, but you can use the
generate_hook_element_display
filter.There is an example of usage in this article:
https://docs.generatepress.com/article/generate_hook_element_display/ -
Thanks Alvind
Tried this, but it doesn’t work.
For #1 under Display Rules – Location … this should be left blank ie ‘choose’?
#1 Block – Content Template [1574]
#3 Post ID – 1351
#2 Hook wp_body_open<?php add_filter( 'generate_hook_element_display', function( $display, $element_id ) { global $post; if ( 1574 === $element_id && is_page( 1351 ) ) { $display = true; } return $display; }, 10, 2 ); ?>
I need a little more info.
How do each of the 3 content templates relate to their pages ?For example in posts, it would be as simple as having Post Categories to set the location.
How does that compare to this requirement ? -
These are all pages (rather than posts)
We have country pages > state > city (state and city as child pages
Content Template 1 is for country pages
Content Template 2 for state pages
Content Template 3 for city pages -
OK. Tricky one.
We could build a function that determines if a page is a top level, a child, or a grandparent:function get_page_hierarchy_level($page_id = null) { if (is_null($page_id)) { $page_id = get_the_ID(); } $ancestors = get_post_ancestors($page_id); if (empty($ancestors)) { return 'top-level'; } if (count($ancestors) == 1) { return 'child'; } if (count($ancestors) == 2) { return 'grandchild'; } return null; }
Then you could use that function within the
generate_element_display
hook like so:add_filter( 'generate_hook_element_display', function( $display, $element_id ) { // get the page hierarchy level $level = get_page_hierarchy_level(); // check if top-level, child or grnadchild if ( 123 === $element_id && 'top-level' === $level || 456 === $element_id && 'child' === $level || 789 === $element_id && 'grandchild' === $level ) { $display = true; } return $display; }, 10, 2 );
Here we grab the
$level
and for each of the three element IDs ( update your element IDs ) we check its level and tell the element to display.This however will apply to all pages… so it may need some extra conditions to narrow that down
David – i have all the IDs of the pages and was planning to add them into each of the 3 hooks so that they call on the 3 Content Templates.
ie.
if ( 1574 === $element_id && is_page( 1351 ,1352,1353,etc,etc) ) {
$display = true;
}Would that work?
It would. If you don’t mind having a large array of numbers 🙂
I don’t mind manually getting all the IDs to put in. Hopefully there’s no significant performance impact due to the large array.
Unfortunately, couldn’t get it to work when following Alvin’s suggestion.
Can you show us the exact code you are using and wrap the code with the code tag?
Hi Ying, this is what I’m using.
#3 Post ID – 1351
#2 Hook wp_body_open -
Try replacing
withgenerate_element_display
.For #1 under Display Rules – Location … this should be left blank ie ‘choose’?
Blank.
Not sure what you mean by hook:
wp_body_open
, if it’s a content template block element, then there isn’t a hook option. Let me know if I miss anything! -
Try replacing generate_hook_element_display with generate_element_display.
Done. Same result.
Not sure what you mean by hook: wp_body_open, if it’s a content template block element, then there isn’t a hook option. Let me know if I miss anything!
There are 2 elements.
1) a Block/Content-Template [id=1574]
2) a Hook with the code we’re discussing (where wp_body_open is under Settings/Hook. Tried a few others in the dropdown, but no luck).Let me know if I can clarify anything else.
Can you remove
global $post;
?And how did you add the code? Via Code snippets plugin or child theme
functions.php
Can you remove global $post;?
Done. Same result.
And how did you add the code? Via Code snippets plugin or child theme functions.php?
It’s in the Hook element > edit Hook
The snippet is not supposed to be added into the Hook Element; you need to use a Code Snippet plugin for that.
https://docs.generatepress.com/article/adding-php/
Then delete the Hook Element you used to add the snippet, as it’s no longer required. The filter to use is
