Bulk Editing Blog Post Formats
    I need to edit about 160 blog posts.
    For example, I need to change the text color, size to 18 px, line height to 160%, font to Poppins, etc.
    It is a very tedious work, I tried it for a few, and I wanted to ask is there a quicker solution for this?
    I will include a screenshot about how it looks like from my end.
    Any help will be appreciated!
    Thank you,
    Mihail.
    as long as you have not specifically set any of those styles on individual blocks within the editor then you can control them from the Customize:
    You can set the Typography and Color values in the Body options
  • Hello David,
    Thank you for the reply. Unfortunately, I can’t set any of these from the Customize option.
    I can just change the Color, and not the body text.
    Is there a way I can bulk edit at least the body text somehow?
  • So if you make changes to the Customizer > Typography -> Typography Manager -> BODY
    Nothing changes ? Or is it just specific content that is not changing ?
  • Nothing changes when I change the Font Size at Customizer > Typography -> Typography Manager -> BODY. It stays the same.
  • when you set the Font Size in the Customizer make sure you choose a unit value eg. px – currently there is no unit been set.
  • Oh, this seems to fix the issue. Thanks a lot David! Sorry for not noticing this stuff.
    I appreciate the help!
  • No apologies necessary, glad to be of help!
