Button Default colors
  • JulieRayCreative
    I have two problems.
    1) The customizer setting for button color seem to be applying to the default WP button (The stacked icon) and not the GB button (The single button icon.)
    I can edit the colors in a global style, but client adds posts and they just add whatever button in, and I want the colors to at least GO with the site, and not the bright blue that fills in default.
    I’ve cleared cache and checked css. Is this expected behavior?
    https://imgur.com/a/0F3qOF5
    And 2) I can’t get the buttons to stop underlining on hover
    I’ve turned off underlines globally and added this css to keep them for the content
    .entry-content a:hover {
    text-decoration: underline;
    but am still getting underlined button text.
    Can you help?
    For issue #1 — yes, that’s expected. The GB Button block has its own default styles and doesn’t inherit color settings from the Customizer. However, you can override those defaults by using this snippet:
    add_filter( 'generateblocks_default_button_attributes', function( $attributes ) {
        $attributes['styles'] = [
            'display'         => 'inline-flex',
            'alignItems'      => 'center',
            'backgroundColor' => 'var(--contrast)',
            'color'           => '#ffffff',
            'paddingTop'      => '1rem',
            'paddingRight'    => '2rem',
            'paddingBottom'   => '1rem',
            'paddingLeft'     => '2rem',
            'textDecoration'  => 'none',
            '&:is(:hover, :focus)' => [
                'backgroundColor' => 'var(--contrast-2)',
        return $attributes;
    For the button underline issue, try replacing your CSS with this:
    .entry-content a:not(.wp-block-button__link, a.gb-text):hover {
    Alternatively, for the GB Button block, you can disable the underline directly in the block settings under Typography.
  • JulieRayCreative
    Thank you! This worked!
  • Glad to hear that!
