Button effect
  • Hello, could you please advise me on how to use GenerateBlocks PRO to create a button with a similar effect?
    Thank you
    1. select the button block, go to the effect panel > transform > rotate, set it to -5deg, click add transition button to add a smooth transition.
    https://app.screencast.com/vXODTX7BlN1vl
    2. select the button block, click the Hover selector at the top of the rightsidebar > styles panel, go to the effect panel > transform > rotate, set it to 0.
    https://app.screencast.com/XtTfY54ovMD5y
    Let me know if this helps!
  • One more question. How can I ideally set the button so that it is displayed in the center but is not stretched to the edges of the phone? I don’t want to use a container.
    Maybe add max width?
    Thank you 🙂
  • Maybe add max width?
    Yes, that will work. And set its margin-left and margin-right to auto to center it.
    You can set the max-width to fit-content.
