Button styling in the GB 2.0
    I want create some styling options for the Generateblocks buttons. Before you could target the .gb-button, but since the GB 2.0 all of the selections like .gb-button or .gb-container and so on have been removed.
    What is the best selector now to target those elements?
    You should be able to see each block’s unique class, for example, gb-element-xxxxxxxx
    https://app.screencast.com/EtPDH9usxCcIo
    You can use that class to target the element, or you can add a class for the block in the Advanced panel and target them with the class you defined.
    If it’s a button block with a link, you can simply use a to target it, if it uses <button> tag, then you can use button to target it.
    If it’s a text block with a p tag, then target it with p, etc.
    There’re many ways to target an element. Let me know if there’s anything unclear 🙂
  • @Ying – This change is disruptive. I have a lot of CSS across multiple sites based on the gb-container class and now I have to manually add the class to new containers. Why did you guys remove this?
  • Why did you guys remove this?
    Because it benifits the performance.
    GB v2 is so powerful that I bet you might not need most of your previous CSS anymore.
