Button text not remaining white – inheriting the active/hover link attributes.
  • I’ve created a style via generateblocks for button named.button-large-
    on the backend, the buttons look fine.
    Unfortunately, on the site the text is blue (not white) and when hovering over button, the text transforms to red (both active/hover are underlined as well).
    Here is what I’d like for it to look like
    Here is what it actually looks like.
    I’m assuming that buttons are inheriting the site’s active/hover link attributes?
    Is there any .css or anything I can do to make the buttons behave the way i want them to?
    It must be something simple I’m overlooking, but any help will be greatly appreciated.
    Thank you.
    The blue link colour is coming from Customizer → Colors → Content → Links. You can remove those settings and instead apply your link colours under Customizer → Colors → Body.
    For the underline, set Typography → Text Decoration = None. You only need to apply this in your Global Style for .button-large .
    That way the buttons will stay white and won’t inherit the default link hover styling.
  • Thank you, i think that did it!
    One last question – i notice that when i hover over the button the button seems to move and move the paragraph text below. Is that just how the transition acts? or is there a way to keep the button steady and not have it move and move the paragraph below?
    That shift happens if the hover state adds or changes a border, padding, or line-height.
    To fix:
    • Make sure the Normal and Hover states have the same border and padding values.
    • If you want a border only on hover, set a transparent border in the normal state, then change its colour on hover.
    This way the button won’t move when hovered.
  • The border thickness didn’t match between active/hover.
    That did it, Thank you. Will mark as resolved.
  • Great to hear that fixed it — thank you for confirming!
