button with 2 icons
  • hi 🙂
    i want a button with 2 icons, one on the left side, one on the right side.
    in generate blocks, i can add the left one. but how can 2 be added?
    thx
  • I am using a grid and it works just fine
    the Button block will only support one SVG Icon inside it.
    Are the icons SVGs ?
  • yes, they are svg´s.
    hm.., so i thing maybe i have to add them with css or js
  • How many buttons will have two icons ?
    As you could build a “button” using a Container Block to which you can add the link ( in GB Pro ).
    Then inside it add 2 x Headline blocks one for the first icon, and one for the text and second icon.
    Let me know
  • ok, this would be a solution.
    but i want the button element to have the look as a button in the backend, so i thing i will you a class, and then add markup with js, or with css pseudo elements.
    thx a lot (y) 🙂
  • One thing you could try.
    In the button icon SVG HTML field, you cab can add multiple <svg> tags, to show 2 icons.
    You would need to copy paste the HTML inside there.
    Then give the button a class of two-icons and add this CSS:
    .gb-button.two-icons {
        position: relative;
    .gb-button.two-icons .gb-icon svg:last-of-type {
        position: absolute;
        right: 20px;
    It will position the 2nd ( last ) SVG icon to the right of the button.
    Just make sure the button has some right padding to accommodate it, and adjust the above right: 20px value to suit.
